front dress
Lee12609
he's talking about engine driven assesories, water pump, alternator, a/c, etc.
theres plenty of people running fox setups, but i dont really see a reason to. the only advantage is aftermarket brackets.
1990F150
i'm converting a 96 v6 car to a carbed 5.0l and the 94-95 brackets are harder to find. where as the fox brackets are a dime a dozen. i'm just wondering about any possible issues with using them. i know the alt bracket will have to be notched for a g3 alt and the a/c compressor is different from what i hear. but will they line up with a 94-95 water pump? any clearence issues with the radiator? i'm retaining the factory electric cooling fan also if it makes a difference.
Paul
Just save yourself an enormous amount of trouble and get the right brackets. They're not that expensive.
Lee12609
you'd have to use the timing cover/water pump to match the rest of the accesories. i know the fox water pump gets real close to the fan in an SN, but dont think it hits.
blackpony
if you are using the sn95 timing cover, then you will have to have the sn95 brackets....
