Front End (Driver) Wheel Squeak
Ralphis
Ok here goes.
Seems like it's brake related. I hear this constant squeak at any speeds. When I put on the brakes (slightly) it stops right away.
I am also able to lift the front wheels off the floor and turn the front wheel by hand and I hear the same squeak (driver side only).
The only way to get rid of it (squeak) is to apply some brake lube (squeak away stuff - forget the name) almost everywhere and then it will go away for awhile but come back. :BangHead:
Any ideas ??
thanks ... :wave:
R
Ralphis
Nope .. but like I mentioned (and I did just now before taking her back out)
Removed the pads .. caliper pin and "lubed" up contact points where the pads touch the knuckle etc ... where the anti-rattle clip touches ... the caliper pins etc ...
went for a ride .. squeak gone ... for now ...
JDwhite98gt
its a common mistake that people dont pull out the sliders wipe them down well and re-lube or for that matter put anti-squeal on EVERY contact point between the caliper and pad. I've done so many repairs at my old shop where do it-yourselfers bring in their cars for us to fix squeaks on pads and rotors they did a few days before.
R
Ralphis
I think you maybe correct on that one .. not sure now if I had lubed them up last few times I did the work (caliper pins) .. anyhow .. as mentioned for now the ride I took (about 40 min) I heard nothing .. so that's a good thing !
Thanks and will let you guys know
Ralph
