Fuel pressure gauge?
Cetz
Hi I have a question can I run my fuel pressure gauge from my fuel pressure regulator. Or it has to be ran from fuel rail?
There are no spots on the factory regulator to tap for pressure that I am aware. Depending on the year the schrader valve on the rail is the easiest place.
you can still put the sender in the rail. If not you would probably need to switch to AN lines and add a spot for a sender/sensor.
Makoto
Houston
I have after market regular and trying to put gauge in the pillar
same process. i have a gauge on my rail before the FPR.
what you want to gauge is the pressure at the rail BEFORE it sends fuel back to the tank.
