Fuel Pump *help*
duff daddy
For under $100.00 you can get a good walbro pump, your vehicle is built with a return style fuel system so the added LPH wont really make a huge difference because whatever isnt used will be returned to the tank.
As far as injectors dont worry about them until you have some supporting mods.
ThePope
I thought 98 was the first year of the return style fuel system?
duff daddy
I know 96-97 were return some 98's were retun also, and some were returnless 99+ were the beg of returnless I believe.
Leonide
my car is a return fuel system. i need the plug adapter before i can put my Walbro in there. but the fuel pump is a worthwhile upgrade, because it's so cheap and sets you up for some forced induction upgrades at a later time.
ThePope
How can you tell if you have a return fuel system or returnless?
greenscobie86
The Big Apple
My 96 has done it since i had it too, for a whole 2 years...
My other 96 doesnt whine for some reason... I think its a luck of the draw type of thing honestly.
vermilion
maryland
ground wires for other electronics touching each other. normally it wines before start to prime. thats a good sign FYI. behind my dash cluster i have my shift light wired and it wined then.
