Fuel Question
ZachSav
Can i run a Walboro 255 Fuel pump from a 95 v6, and keep my stock regulator? my cars pump went out and i have the 255 from my old car, and need my car on the road again. Would i need to make any changes?
Thanks.
G
GREG@SN95
Guest
Re: Fuel Question, NEED ANSWER TODAY!
Pretty sure the pumps are the same... I think you'll be fine swapping the pumps...
Z
ZachSav
but will the regulatorbe able to hold going from 190 to 255?
G
GREG@SN95
Guest
Should not make a difference... you should be fine...
castine917
wyoming, mi
can you clear up what car the pump is going onto as you said
"Can i run a Walboro 255 Fuel pump from a 95 v6, and keep my stock regulator?"
but not what it is going into. i assume another 94-95 mustang but????? if it is then you will be fine. regulator does not just go poof gone because a bigger pump was added. it will still regulate to stock pressure.
G
GREG@SN95
Guest
yeah... 255 pump on a stock GT regulator will work just fine... no worries my friend.
Z
ZachSav
i assumed sin i posted in the 94-95 5.0L section it was implied. but thank you, i plan on getting an adjustable regulator later, but the cash isnt there now lol.
Z
ZachSav
thanks for the quick replies... now off to work to get my tools lol
castine917
wyoming, mi
just wanted to make sure it was not posted in wrong area. good luck getting it going.
I say as long as its just a high volume pump and not a high pressure pump you should be good, even then it might not matter.
Staff online
