Fuel Rail Question
pilks
Stupid question....
If i Do a pi intake manifold swap, will i need a fuel rail made for (99-04) or is it still 96-98 ??
And what exactly is the "sensor fitting"?? and will i need one?
Also can someone explain return style with regulator and non return style.
http://www.rpmoutlet.com/musv8fuelr.htm
looking at those because their red....
Marvin97
Glasgow, Ky
its a return style fuel system. 99 and up use a returnless style fuel system if im not mistaken.
pilks
pilks
mind explaining the difference, even if you know little..... you know more than I
SnakedMark8
Your return style sytem regulates the pressure with a regulator that closes off the fuel return line against the fuel pump line pressure. The fuel from the regulator that isn't blocked off to maintain your pressure is then routed back to the fuel tank and then recirculated again.
The returnless system has a modulated pump that the EEC controls by monitoring the fuel rail pressure and some others. The fuel pump module speeds and slows down the pump to regulate the programmed pressure it is set to maintain. There is no regulator and so no fuel is sent back to the tank or recirculated.
You want to stay with your stock return system.
