Gauge Cluster lights -- help
94Pro-5.0
Little Elm, TX
I took the cluster out of my sisters GT b/c they are too dim, and i found these wires unplugged. where do these wires go?
1FastGT
those look like aftermarket (ebay) gauge faces. there should be like a little box or module they plug into. if their not there just remove them. or get a new setup.
94Pro-5.0
94Pro-5.0
Little Elm, TX
well i dont want ot buy new ones b/c its not my car, and i dont want to remove them b/c they are on there pretty good.
wheres the box they should plug into?
1FastGT
you can have your sister order a new set of gauge faces and it will come with the "transformer" but if its in the car i assume it would be under the dash?
BOS-94-003
Theres no set location of the box as they are aftermarket. If visability is ok with them on there then just put em back. If gauge visability is a problem then remove them. They should just be overlays with the stock gauge mat underneath. If they are indiglo gauges not only will you need to find the power box but youll also need to locate the contol pad for them to operate properly.
