Gauge Installation questions...
SoddyRebel
Im putting a auto meter trans temp gauge and air/fuel gauge in a piller pod. Running the power to the gauges isn't a problem, but where does the wires or w.e hook up to the tranny, u drill into the pan or what? I think the air/fuel goes to an oxygen sensor, but ifs somones installed these id like to get some info, thanks
Lightning Struck
tap the pan for the trans temp and the a/f goes into a bung that should be installed into your exhaust, close to the headers I think
Paul
Do you have a wideband oxygen sensor, or one of those ones that just taps into the sending wire on your factory O2 sensors?
SoddyRebel
they are just the stock oxygen sensors, the gauge is pointless i kno, but i like the "lightshow".
Lightning Struck
:rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: gives you something to look at while you drive huh :D
Paul
Okay, in that case you can actually wire it directly into the wire coming from the ECU harness. There are diagrams online with the 94-95 ECU pinout. Just identify the correct signal wire, tap into it, and run the wire to your gauge.
It is a fun lightshow. :) I used to have one back in the day.
Paul.
