Gearheads: will this diff work for me?
24hrlemons
90 Mustang Gt >8.8 Positract 4 lug with 3.73 gears
I have a SN95 '98 V6 t5, open rear, rear disk brakes, 5 lug. Can I buy this rear and put my axles in it to give 5 lug? Also, is the ratio the same as on my car (bonus)?
Or, I guess I could with a lot of effort swap parts and make the open gear a posi? are the internals compatible?
I'm road racing the '98 and need traction coming out of turns.
Thanks,
:thumbsup:
uncltrvlnmatt
Pa.
From what I understand, the fox body rear end housing is the same housing used on the sn95. BUT, the sn95 used longer axle shafts. So yes it will work but you will need longer axles.
atlanticblue98
99-04 is wider, 94-98 is the same size.
i have a friend who used his 7.5" 94-98 axle shafts in a fox 8.8" housing
it will work
2slo95fiveoh
Lawrence, Kansas
The 94-98 8.8 axles are .75" longer to compensate for the added disc brakes... You can take the axles, brakes (including brackets)
and put them on your fox 8.8 housing and call it a day.
24hrlemons
atlanticblue98
24hrlemons said:
Hmm.... I was checking for prices on said rear end I saw for sale to see what they go for, and happened on an article...
http://www.carcraft.com/techarticles/116_ford_8_8_rear_end/limited_slip_differential.html
This says that they made the 94-99 rears with 31 splines, vs 28 for the earlier ones like that guy is trying to sell. Hmm.... doesn't seem like those axles would fit after all. *#*(%^&
that is wrong, they dont have 31 splines. but that doesnt matter because you wouldnt be using 94-98 8.8 axles anyway. you would be using 94-98 7.5" axles in a foxbody 8.8.
and all 7.5" axles are 28 spline
Petek
94-98 Mustangs all use 28 spline axles, the axle shafts between the 7.5 and 8.8 of these years are interchangeable.
atlanticblue98
thats what i said.
Petek
if that is what you said, than you said it in a confusing manner.
