Going from one amp to two
JiMi_DRiX
Tucson, AZ
I'm finally going to put the front component system in my car, but I'm going to have to run an additional amp. (one 4ch, and one 2ch for the sub) I currently have an 8gauge wire for power. Now after some research and all, I'm not sure what to do for splitting it into two power sources. Can I run the 8, and split it into two more 8's with a distribution block? Or do I absolutely have to run a 4gauge, and split it into two 8's? They are not huge amps.
And for the remote wire to turn the amps on, I read that I can just run a jumper from one amp to the other, instead of running two remote wires from the stereo?
I think that covers everything at the moment!
joekd
Ct
Yes on the remote wire, one is fine for both since it wont have any draw on it
As for the wiring, I would go 4 ga (or even 0 ga) and then split with a dist block
JiMi_DRiX
JiMi_DRiX
Tucson, AZ
I have some 4ga, but I'm looking for any chance of going around having to run a new power wire! drats. Whats the concern with using an 8ga and splitting it? Just not big enough?
Matt94GT
Im sure 8ga will work just fine, people exaggerate quite a bit. If your going to be cranking it and going into comps then obviously you want 4ga minimum. But you are only going to probably be listing to your stereo at 25% capacity. If you have 4ga around I suggest using it.
You will hook both amps up together with a distribution block, they come in all shapes and sizes.
joekd
Ct
8 ga is only supposed to be good for 100W or 50A draw, the mustang is one of the top 5 easiest cars I have ever run power cable on so that isn't a reason not to do it
the speakers hooked up to the amps will also make a difference in how much current the amp draws, but we still need to know which amps you are hooking up.
missed that sorry. The sub amp has 60 amps worth of fuses on it, what does the RF have in it for fuses? Take that number, add it with 60, and is it bigger then 100Amps total that the 8 awg can safely supply? The sub amp already has 4 awg inputs....
JiMi_DRiX
JiMi_DRiX
Tucson, AZ
The RF amp has two 25amp fuses on it. Guess I'll be getting the drill out and running a bigger wire!
jojo22
I would assume to get the larger wire to pass through the firewall, there are obviously other ways, but that is the only thing I can think a drill would be for.
JiMi_DRiX
JiMi_DRiX
Tucson, AZ
I already have a hole/grommett for the 8ga wire. I need to make it bigger for the 4ga. It's on the driver side.
the stock grommet in the firewall is big enough to stick a couple of 4 awg wires through it. I am going to drill when I run 1/0 power AND ground wire but there is no need for 4 awg.
JiMi_DRiX
JiMi_DRiX
Tucson, AZ
I think I remember having trouble with that grommet, thats why I drilled the hole. No biggie tho, its cleanly done.
CanaryGT
Phoenix
I ran 0 gauge. Its only a PITA when running stuff for your on/off. Once your battery is in your trunk easy to run wires....
Mrstangerbanger
CHICO , California, United States
I would run 1 4 gauge or 2 8 gauge power wires.. Also make sure your grounds are the same size...
I have no problem helping anyone with car audio guys. I have been in Car Audio all my life and my family has owned stereo stores for over 35 years so just pm me and all help out...
Also make sure to Sound Deaden your doors and mount your crossovers somewhere they wont get wet..
