Gonna pull the trigger on rear suspension
Daryl
Daryl
SoCal
Pictures of the install!!
They finally sent pictures they took during the install. Very disappointed with them. Most I can’t figure out what the hell it’s a picture of. I’ll take pics tomorrow of what we all want to see: the rear suspension in all its glory!
Daryl
Daryl
SoCal
I added these pics to my Media with descriptions under each if anyone is interested.
Seaford,Del
I'm surprised you didn't put a tubular K-member and control arms on it. It is damn clean underneath!!! Cannot wait to hear how it has improved on the track?
Daryl
Daryl
SoCal
Mo’ betta pix of F/R suspension upgrades:
Alignment guy allowed me to get up underneath while it was up on the air so I could get better pix of the entire rig!
Daryl
Daryl
SoCal
Sanitary installation. That is a lot of hardware under there!
Yeah. It’s amazing how it’s all engineered to fit and each component compliments the other. The rear grip is 1000x better and the coil overs/Bilstein’s just make it handle exactly how I wanted it to! Normal, everyday type driving is comfortable yet it eats up curves, turns and hairpins. I’m really, really happy with it!!
Tillerman77
Southern MN
I have a number of MM pieces plus Bilsteins on my 97, but stopped short of your "mega-burrito" installation. Too frugal for that (retired)! That said, I am sure your car handles fantastic. I know that I am quite happy with how my car turned out, even with less exotic hardware.
badass98svt
Now that it is all in there, do you hear and clinks or anything?
I have most of the stuff other than a TA, and I have a clunk I've been chasing out back.
(I have solid bushings in my LCA, and have the PHB out back as well which is solid bushings.
Daryl
Daryl
SoCal
I did just notice a clunk. Not all the time, just over significant bumps, dips, potholes etc
badass98svt
Out back? Mine almost sounds like it's the spare tire banging when I go over a good bump.
badass98svt
Did you change out the stock pinion snubber to a shorter one?
Yes, many years ago.
I've been running the same rear springs (H&R SS) since 2008 or so. Before that I had another set, and there's been a shorter snubber on since then. I've been through a couple. My noise started after a PHB install it seems. But I had A LOT of work done on the car at the same time though.
Daryl
Daryl
SoCal
“If” memory serves, I believe the MM installation instructions for PB/TA called for removing the snubber. I did already have the MM shortened version in there.
badass98svt
Hmmm...I didn't do the install, I'm gonna look under there and see if it's gone.
white95
Apex Junky
Prairieville, LA
I’m not sure if mine was changed or removed, so, I need to check as well.
Any additional brace, rod or suspension component installed with solid/spherical bushings, clamped to the axle or welded in place will greatly exacerbate NVH.
peasant99
