good buy?
El_Diablo
are gt40 y303 heads a good buy at $710? i need to know in the next couple hours :)
LAFENATU
You can get used TW's for probably another $100.
I wouldn't spend $700 on GT40Y's. If your willing to get them ported, than they can go a long way. You can get them to flow better than a stock twisted wedge but that means spending another $300-$400 in port work.
.02
E
El_Diablo
i can do the port work but i already have studs and im on a tight budget, its down to gt40's or edelbrock heads and try and find the edelbrocks for around the same price
LAFENATU
It is your call..Edelbrocks will make more power than a GT40Y out of the box.
If you can do professional port work why are you questioning it?? Not everyone can do port work and do it RIGHT...
Going into a head with a dremel is not good unless you know what to do. You can actually make a head perform worse if you don't know exactly what you are doing.
Sometimes it is worth it to look around. My buddy just picked up a set of stage 3 ported Edelbrock Performer RPM heads for ~$900...new.
This is your call man - you know what your goals are.
topless95
Check with some local machine shops, people will drop heads off and never pick em up so the shops will usually sell em for a good price
E
El_Diablo
true... oh, and btw, i can do the work but i haven't in a while, that coupled with not knowing sbf's to well and you may understand why i was iffy about the heads, they have since been passed up ;)
