good combo for over 400hp?
95Grandtouring5.0
Afr 185's. Port job and a valve job. Really big cam. Trickflow top of the line intake ported. And you might be able to reach 400 at the flywheel
FMSGTS
Conneaut, Ohio
I'm running a 331 with 185 AFR heads, Comp Cams 35-522-8, Edelbrock RPM II intake, 30 lbs injectors etc. I put 374 rwhp & 360 torque & ran 11.80 at 116 in a full weight 95 GTS. I think you would be happy with the 185's. Good luck
LAFENATU
It is going to be easier to hit your 400HP goal with a 347. You didn't say whether 400 was RWHP or at the crank.
I don't know if you have emissions there but I would look at AFR 185s or the new 190's depending on when they are released. Shoot for at least 300in/225ex flow
Run a cam with at least 224 degrees duration on the intake. You can probably run more though. You'll also want to stick with 112-114 lobe separation. Ed can really work wonders allowing you to still pass emissions and make great power if need be.
Don't be afraid of compression, run 10.5-11:1.
Holley Systemax intake.
AFR 185 or 190 heads
Custom Cam
30lb injectors
75mm throttle body
tune
You should be at 400 or real close.
94 Sn-95GT
I would do a 347 for the same money its a no brainer.
Also I would look into the TFS TW Fast As Cast heads. stock exhaust pattern and loaction but better valve placement.
I
i_love_my_stang
the pistons i have will run a 10.37 compression ratio with a 58cc combustion chamber, and i bet if i get a cam from ed curtis that should bump up the compression a bit more should'nt it?
94 Sn-95GT
What sized compressed head gasket? how far is the piston in or out of the hole? how far down is the top ring land?
And finally how does a cam effect the compression ratio?
Addermk2
I run those exact pistons in my "short rod" 347. 10666-030.
My static compression is 11.25:1. Runs on 93 octane.
if I were you, I'd run a larger head with a custom cam, and something along the lines of a victor 5.0 intake, maybe even a TFS Box-R
I
i_love_my_stang
like the edelbrock victor jr. heads?
WarMachine762
It doesn't affect static compression. It affects cylinder pressures, a cam with lots of overlap is gonna bleed off cylinder pressure, so you run more compression with larger cams to make up for it.
Addermk2
Paul said:
Addermk2 said:
Runs on 93 octane.
You suck. I wish we had 93 octane around here. :(
We have 91 too. I've run the car on 89 before, but I didn't put the boots to it at all.
210cc vic jr's are pretty nice heads. I was going to run AFR 205's on my car, then I picked up a set of worked Canfields on the cheap.
Venom351R
Maine
More timing = more power. We used to have 93 here until the $4 a gallon gas hit last summer now all we can get is 91.
94 Sn-95GT
exactly but he's talking about static compression and asking if a cam can help bump that. The answer is no. Cam controls cranking and running compression.
Addermk2
LAFENATU said:
Addermk2...
Cause he can run more timing.
idk why i always do that... but I get Paul, and LAFENATU mixed up when they post
