WUZa5oh said:If you swap the SN95/302 accessory brackets over to the 351(you should, it's easier), you will need a spacer on the balancer to line up the belt.
No. You don't.
Paul.
Paul said:WUZa5oh said:If you swap the SN95/302 accessory brackets over to the 351(you should, it's easier), you will need a spacer on the balancer to line up the belt.
No. You don't.
Paul.
WUZa5oh said:Paul said:WUZa5oh said:If you swap the SN95/302 accessory brackets over to the 351(you should, it's easier), you will need a spacer on the balancer to line up the belt.
No. You don't.
Paul.
I can't argue with you on that. A buddy of mine put everything together at his shop, I just ordered the parts as needed.
I just took a look at the receipts and here's the spacer I thought I used (maybe it never went on, can't remember)
http://mustang-parts.cjponyparts.com/search?w=m8510b351
it came with this balancer
http://www.parts123.com/parts123/yb...~S2AL0P42VF71173618014a~Z5Z5Z5~Z5Z5Z50000016e
for some reason they're selling them individually now, I got them together for 237.45 a little over a year ago.
this is the flywheel I used
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_66968_-1
this oil pan kit
http://store.summitracing.com/partd...908282+4294924760+4294840125+115&autoview=sku
and the headers
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_36768_-1
I forgot to mention, I had to swap over my 302 timing cover and use a "short nose" 94/95 water pump(the Lightning uses a different cover and a longer water pump)
My suff is definitly not the best stuff out there, but it got the job done at a reasonable price. Prices have gone up since then though.
And Paul, that's a badass engine compartment :boink: makes mine look like a hyundai :crying: I see a fox T/B setup, are your accessories Fox also ? Maybe that's the difference. The T stat housing is obviously different too. It all looks amazing !!
xploder17s said:before june i would hope lol. i wanna get my suspension done too.
