Got a 351W question...
Paul
WUZa5oh said:
If you swap the SN95/302 accessory brackets over to the 351(you should, it's easier), you will need a spacer on the balancer to line up the belt.
No. You don't.
Paul.
WUZa5oh
Paul said:
No. You don't.
Paul.
I can't argue with you on that. A buddy of mine put everything together at his shop, I just ordered the parts as needed.
I just took a look at the receipts and here's the spacer I thought I used (maybe it never went on, can't remember)
http://mustang-parts.cjponyparts.com/search?w=m8510b351
it came with this balancer
http://www.parts123.com/parts123/yb...~S2AL0P42VF71173618014a~Z5Z5Z5~Z5Z5Z50000016e
for some reason they're selling them individually now, I got them together for 237.45 a little over a year ago.
this is the flywheel I used
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_66968_-1
this oil pan kit
http://store.summitracing.com/partd...908282+4294924760+4294840125+115&autoview=sku
and the headers
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_36768_-1
I forgot to mention, I had to swap over my 302 timing cover and use a "short nose" 94/95 water pump(the Lightning uses a different cover and a longer water pump)
My suff is definitly not the best stuff out there, but it got the job done at a reasonable price. Prices have gone up since then though.
And Paul, that's a badass engine compartment :boink: makes mine look like a hyundai :crying: I see a fox T/B setup, are your accessories Fox also ? Maybe that's the difference. The T stat housing is obviously different too. It all looks amazing !!
Schiffy
Schiffy
Norfolk, Va
WUZa5oh said:
Paul said:
No. You don't.
Paul.
this oil pan kit
and the headers
You are my hero... QUESTION... you said yours is basically stock... do you know what it puts down? any dyno numbers? I would like to know what i'm going to be making right of the bat with a relatively stock 351.
but everything you sent me is amazing... You are my newest favorite person on SN95forums! THANK YOU!!! not that you haven't helped a lot either Paul... I appreciate what you've said, and even the whole...is this really worth it comment, back on page one. makes me feel like you might actually give a shit. LOL... i appreciate everything fella's, now i just gotta get that engine... only need $200 more!!!
WUZa5oh
Thanks for the kind words. I'm nowhere near done with it, it's not even tuned yet. So I don't have a clue what it makes. I've been told 260 rwhp +-, it sounds low, but a 302 realisticaly puts down 210/215. The difference is in the torque, it's a BIG difference. It's lots of fun on the street with 3.73s . Plus the potential is where it's at, you can stroke it big.
I have baby GT40 heads and the matching intakes, there are lots of heads that will give much more power to the 351 I hear.
I saw this question on another forum, I think it was you also so I'll help here instead.
WUZa5oh
I'm still using the stock MAF, 19lb injectors, and stock fuel pump. I have a 90mm MAF, 30lb inj, and a 255lph pump to install. I'm having the lower intake ported soon and then will have it all tuned. I'm hoping for 285/290hp then. I think the tune is where I'm going to find some good HP.
Paul
Bad Black - I really think you should spend the money on mods for your 302 instead. Once you've bought then engine, the headers, the oil pan, the motor mounts, the belt, the balancer, the flywheel, etc. etc. you could have a modded 302 that makes far more power than a stock 351. Plus you'll have the added benefit of fuel injection and decent mileage.
Having done it - I would say that swapping a 351 in isn't worth it unless you're going for BIG cubic inches and have a relatively expensive combo. Otherwise, a 302 or 302-based stroker is the more reasonable alternative.
WUZa50h - my motor has OEM 94-95 bracketry. I change to a fox TB setup because I couldn't get a big enough TB for a SN95. (that's a 90mm) The thermostat housing is nothing more than a chunk of aluminum with a -20AN bung welded on it.
The big cube motor do have a nice torque advantage though. My previous (very mild) 418 made 442 ft. lbs. at <3000 rpms.
Paul.
WUZa5oh
Nice stuff Paul. I'm not going to argue with somebody with a setup like that. That takes patience and I don't have any.
The spacer came as a kit with the balancer, I checked the receipt. It probably never went in. I apologize, don't want to put out false information. Thanks for clearing that up.
The 351 is good to hold more power without splitting down the middle . My plans were to have a blower on it, so the stronger block made sense. I'm actually leaning towards a turbo kit, so it makes even more sense now. This year I'm painting car, so either one will wait at least another year, just looking ahead.
Schiffy
Schiffy
Norfolk, Va
Paul, my dream Engine has alwasy been a 408, don't ask me why, i don't know... I've just always wanted one...LOL... I look at it, as though,i can pick this up now for $500, use my brackets, and the balancer already on it. my buddy has an aluminum 28oz flywheel, he's selling me for $125(he owes me for some stuff i sold for him) I'm leaving it carb'd, and running it around like that. I've also got a buddy who's got parts for it, and a set of Roush heads, so i'm going to build it slowly over time... I don't know... there's just something about building a 351, that give me a hardon. LOL... the 302 just doesn't do it for me... HOWEVER, i'm going to offer the guy $550, and see if he'll throw in the 302 longblock with the 351, since he was only asking $100 for the 302 anyways... plan on turning that around into a small profit, to put back into the 351...
Paul
A 408 is certainly a good choice. You can use a relatively inexpensive stroker kit and make good power (relatively) inexpensively. I'm a huge proponent for big cube small blocks. The next motor I build will be a 445 cubic inch SBF from a World block.
If you've got your heart set on it, go for it. Just be sure you have a good plan in place before you dive in to make sure you don't end up with a non-running car and a bunch of parts. You need to take into account the cost for EVERYTHING (gaskets, bolts, shop consumables, etc.) unless you can afford to just pay for it without thinking about it. You'd be amazed at how expensive all the little crap ends up being.
Paul.
Schiffy
Schiffy
Norfolk, Va
I'm going to slap the 351 on the engine stand my 390 is currently on(move the 390 to the floor) and i will add pieces here and there, and build it on the stand till I have everything... then I'll take the engine, and the car to the hobby shop on base here, and do all the work there. they haver tools, lifts, and everything i need... thats where my buddy did his 331 swap. I figure it'll be a 2 day process depending on how many people help... maybe just one. as i said, i plan on having everything bolted on, or ready to go on before i yank the stock engine from the car... I'll do the 408 when i get to Houston, as i know some good machinists there.
Schiffy
Schiffy
Norfolk, Va
yeah, Oceana is where my buddy did his 331... Hopefully we'll be doing this one this summer...
Schiffy
Schiffy
Norfolk, Va
xploder17s said:
before june i would hope lol. i wanna get my suspension done too.
You are correct... June 20 is my goal date... but with my son turning 1, 2 weeks from today, money may NOT be there, I don't want to put the Engine in, until i have everything i want (goals stage 1, we'll call it) finished. once thats all done, then she'll go in.
Schiffy
Schiffy
Norfolk, Va
...*update*... I just sold my old T5, so i'm now only $100 short of purchasing the 351W!!! hopefully i'll sell some more shit tomorrow, I've got a guy looking at some rims... I've also got a for sure $100 friday if i wait that long. :banana:
Jerry santos
