Got a code just wondering....
Downshift
Just curious what yall think the first thing to check on the egr for a code 332. Its EGR valve opening irregularly if I remember right. I just switched my intake to a 93 cobra and am running a 93 cobra EGR(Brand new). The position sensor that goes on the back of the egr looked exactly the same for the fox body as my SN95 one so I used that. Code just bugs me more than anything haha. Im open to suggestions, and it happens very randomly havnt been able to pin point it to a certain RPM or anything. Quick check revealed that the vac lines are all intact and on too. Thanks ahead of time.
Downshift
No one has any ideas? It was fine for a couple days and then just came on randomly again.
ryclef331
Thats a tough one man. I know you said the valve was new but I'd pull it off and clean it up real good. The other thing, is the lower a 94-95 lower? The Fox body egr setup takes its exhaust gas from the heads, up through the lower intake, through a channel in the upper intake, to the egr valve. Are you SURE that this isn't blocked off some how?
Downshift
Ya I cleaned it up really good. I used like 3 cans of brakeclean and a thing of superclean just on the inside of the intake and egr ports. The lower is just a normal GT40 I suppose, it does have the hole coming up from the heads like you said though. I guess I will just start trying egr parts, I work at a parts store so I can return them if it doesnt work. Just curious on what I should start with first haha.
Downshift
I got out my book and the code was insuffient EGR valve opening, not irregular like I thought. I havnt had a chance to start working on the problem with finals and essays so after tomorrow I can start trying to figure it out.
EdgarR213
