Got her started but......
Venomized
Iowa
I got it started tonight but Im having a timing issue. I set it at 10 btdc(take it to 0 and turn it clockwise to the 10) on the crank and the rotor at the cyl #1 position and to get it to start I have to turn the dizzy to the right to get it to idle at all. During idle it has a "knocking" noise. When im using the timing light its showing the little slot thats either on the bottom or side off the balancer.
The setup is:
B303 cam
Scorpion RRs
BBK O/R h pipe
BBK shortys
Any ideas?
94RedGt
Hialeah, Florida
Make sure all ur spark plug wires are correct, knocking or ticking, ur new rockers could be adjusted incorrectly, u no longer have the stock cam so the base timing could also not be 10 anymore, those cams with advance already in the grind i think , 2 or 4 degrees of advance i think.
Did you make sure that cylinder #1 was at tdc on compression stroke when u aligned the rotor to the spark terminal, go check that , take a long screwdriver and insert it down the spark plug hole of number #1 and rotate the engine to compression stroke on number one, check ur distributor rotor to see if its pointing to or close to number one or i think that does not really matter but its better, the align one of the post on the cap to the rotor and that should be spark for number one , then just follow along with the firing order and wire all ur cylinders, there u have 0 degree at BTDC or close, remove spout connector and start the car, time it to what ever setting is that u want it to run , if the balancer still has the marks in the correct spots then u should be good to go, if the have slipped then u should get a new balancer.
Venomized
Venomized
Iowa
All the wires are correct. I made sure to go over them twice. I set it to 0 on the balancer and the rotor to the #1 spot and it will fire up but shows 20+ ATDC on the balancer.
The sound is definately a knocking. Kind of a detonation sound. If i turn it to the left it will go away but the car will run for a little while on its own (loping hard) but die shortly after.
Venomized
Venomized
Iowa
Also is it absolutlely necessary to run a bigger fuel pump when doing cam and rockers and exhaust? I have a 255 lph walbro with install kit sitting here if so.
Venomized
Venomized
Iowa
Ok i tried everything to no avail. So i pulled the front cover off to check the timing marks. Low and behold the crank timing mark was off 2 teeth (to the right of the cam gear mark) I lined it up and checked the #1 piston and its at TDC. Now I hope it'll time right.
BTW i know about the SPOUT plug.
Venomized
Venomized
Iowa
Got everything set and started putting it back together and now i find that my balancer is almost completely apart.... UGHHHHHH!!!!!!!!!!!!!
Venomized
Venomized
Iowa
Your right.
Just getting tired of everytime I fix something, something else breaks haha
it happens.
there are a few common problems with these cars. if you stay caught up on them then you'll be happy well into the 200,000 mile mark.
unless you beat your pony like a rented mule that is
Venomized
Venomized
Iowa
Well my car has over 200k now. It was stored winters and driven by a late 30s attorney for its whole life. The car was completely stock when I bought it. Other than normal routine maintenance it hadnt been touched.
94RedGt
Hialeah, Florida
So was the balancer ur problem ? If it was completely appart then that was giving u the timing marks on the incorrect spot so u were adjusting it no were near of were it needed to be to even be driveable.
Venomized
Venomized
Iowa
Not sure yet since noone near me stocks a replacement balancer. Gotta order one from summit. Im gonna pull my intake manifold as well and recheck the valvetrain adjustment while Im waiting on the balancer.
Venomized
Venomized
Iowa
Ok balancer is ordered (I went with the summit one instead thanks CC) I also purchased a rocker shim kit. I didnt need one when I adjusted my rockers because none of them went past 1/2 to 3/4 of a turn but Im going to recheck them and I would like a 1/2 turn on all of them.
