Got power, no crank
jwhisl
Oklahoma
Started a new project a few months back converting a dead v6 car to a 5.0 I pulled my driveline and engine wiring with it and dropped everything in. I left the dash, fusebox, and interior wiring. Thing is the car won't crank. Literally everything else in the car seems to work. Interior lights, windows, blower motor, fuel pump, even stereo all get power. Battery only drops .2v when I try to start. Need help
Edit: checked all plugs and replaced ignition switch
Start simple and ensure your grounds all got hooked back up. After that check the starter wire to see if it has power at the relay/solenoid. if all that looks good check the neutral safety switch.
J
jwhisl
Oklahoma
Forgot to mention I stuck a fuse in the plug for the safety switch. I need to test everything else
J
jwhisl
Oklahoma
I think I got the grounds. 1 by ecu, 1 from battery to block, several by fuse block.
Cwacaser
