Gotta have the WOOooo to go with the GOOOOoooo.... Brake upgrade!
Anrev
Been wanting to do this upgrade for a LONG time. The stock brakes on my car SUCK. So I got this stuff.
I got these front rotors:
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=554
These front calipers:
http://www.buyfordracing.com/shop/product_info.php?products_id=542
And these rear rotors:
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=1028
And then I got stainless steel brake lines for the front:
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=919
And the last bit arrived today!
:banana:
Now I just need the time to install all this and the Eibach springs and Tokico Blue shocks.
Awesome
im waiting on the brown truck to show up with my 10 anni calipers
post pics after the install :thumb:
A
Anrev
I think Im going to get the calipers powder coated the same color as the car.
Paul
Wow, I really like the nice flat black calipers. I think I'll put those on the notch. Thanks for the links Anrev. :) Nice setup.
A
Anrev
Yeah they got the best price on them. Get them before the price goes up like everywhere else.
LAFENATU
Just curious why you got all of that - this will do the same thing as the other set I listed below and it includes stainless lines for $349.00
Upgrading the rear is never a bad idea, but not necessary. The fronts do about 80% of the stopping. You only need to upgrade the rear if you are road racing a lot.
Either way, the brakes are nice. :thumb:
image.php
Mach 1 Brake Package
� Same calipers as used on the 2003-2004 Mach 1
� Fits 1994-04 Mustangs / Cobras
� Kit includes:
- 2 New Brembo Brake Rotors
- 2 New Black Mach 1 Brake Calipers
- 2 Stainless Steel Braided Brake Lines
Includes Brake Pads & Mounting Brackets
Paul
image.php
So if I buy this kit for an 89 notch with 94-95 spindles and such - will the brake lines fit? Or was there a change in brake lines/fittings from the fox to SN chassis?
Paul.
LAFENATU
All said and done...
The way I would do it on a Fox would be:
- 99+ spindles
- SN95 GT or Cobra master cylinder
- SN95 GT brake booster
Lines should fit without issue.
EDIT: yeah they were changed...dont know the specifics though - lemme find out. I have a buddy that worked for Maximum Motorsports...I'll check with him.
A
Anrev
No the lines wont fit. The Cobra uses a coarse thread banjo fitting. But it comes with the upgraded brake lines.
I went this route cause I wanted Mach 1 calipers (plain, no markings) and cross drilled rotors. As for the rear brakes. I just wanted something to fill out the wheels. And 13" rotors on the rear look cool.
Paul
Let be more specific...
If I order the kit complete with the stainless brake lines, will they attach correctly to my existing fox hard lines?
I already have 94-95 spindles. I don't want the 96+ spindles.
Paul.
eliyarbrough
Nocona, TX
Props on the title!!! It took some thinking, but I figured it out.
I need new brakes on mine, I keep putting it off. I don't drive it much though! Looks good!!
LAFENATU
Paul.
I just recieved an Email back from my buddy that worked @ Maximum Motorsports.
Paul will have to get an adapter to fit one of the SN95 lines to the fox hard line, or just buy a set of Fox-SN95 braided lines from Maximum Motorsports.
Paul
Great, thanks for the info. I didn't know MM offered an adapter line.
Jerry santos
