Shit how much for all grounds ?I don't have a stock ground strap but I have 4 awg high current cable and some ring terminals where I could make you one better/thicker then the stock cable. Measure how long it is and I can put it together. While your at it measure the battery/chassis ground and we can upgrade it as well.
If you happened to that'd be great. The outer nut wouldn't be bad, but that inner stud is hammered. I'm sure I could get them apart with my torches, but...I'm sure I've got one of those studs. Let me check my stuff tomorrow and I'll let you know.
I'm sure I'll be able to get the nut off, but the head of the stud is pretty bad. I'm not even sure I could tighten it back on with a socket. I could put it back on the way it came off which is to not separate the nut, strap and stud or I could make a new stud, but if he has a good stock one, I'd rather just use that.a little penetrating oil and it would come off/clean up.
Thanks. I work in a secure building so I don't have my cell phone. I'll go out in a few min.I sent you a text.
