Guage Wiring
94 DropTop
What did you guys use for your power source and your ground on you guages. I have a elec.water temp and a volts guage. I cant figure out what to do cuz i need 4 grounds and 4 power. Pics would be awsome to.
Mesarina
for the ground, any bolt under the dash that touches metal would be ok, for the positive of the light, use a tester and check the back of the a/c controls to find a positive signal, move the dimmer switch to see if the intenisty of the light on the tester changes, if it does, then use that wire for the light of the gauges...
You should be able to find a ground on the left of the dash low that runs the defrost / light switch or you can use the radio ground. There are plenty of options. Or you do what Mesarina said - any metal bolt.
94 DropTop
i got them in the bulb covers dont work very well one is a nice red and the other is kind of orange
