guys i need some quick help
SN95_DropTop
okay so i took off my throttle body to clean and stuff to fix my surge in idle and i need to ask if you could post a pick of your throttle body installed im not sure if i put back right im confused with the two wires on side cant figure how they go back in please help a NEWB out im scared to turn it on im not sure if i put it back right just want to make sure
9psi 98
It's dark out and I don't have any pics saved, but check Ebay anyway. There are always a bunch of close up's of engines. You may see something that helps you out.
quickstang_1994
Cross Anchor, SC
here's mine I hope this helps
SN95_DropTop
thanks a lot guys it was bolted on right the only thing that had me worried was that throttle line in left side of the throttlr body that pulls it open dident know if i had it right, oh you guys should of seen the tb it was really dirty had lots of sludge in the inside was basically all black full of slimey stuff i guess that happens after not cleaning it for 13 years and i did feel car diffrent on doing that so those of u that havent done you should do it
Fryrice
Your not supposed to clean the inside of the TB. It has a coating in it to prevent buildup. Strange your was so bad.
scarface
probably was cleaned before.
Canaryonvskf’s
