H pipe question....
free_ryde
so i just bought a new o/r h pipe. opened the box and it was in two pieces and to attach the two pieces together, there was this coupler thing that connects the 2 together by being welded or something. is it suppose to be like that? do all o/r h pipes come like that? it was a mac btw
Magic
Some time zone
free_ryde said:
if it is clamped, is there a pretty good chance that it will leak?
It can eventually leak....either way is fine. Use a U clamp if you dont have access to a welder....If you can get a welder, then by all means weld it, and use some high temp paint over the welds (to prevent it from rusting)....
realitygt
you'll probably have an exhaust leak in like 2 months if you use a clamp, plus they rust your pipes MUCH faster cause they trap water.
weld it if you can!! or you can just reclamp them every once in a while.
Knuckles281
welding makes life easier, later down the road. just make sure everything is how you want it, cause once it's welded, you're stuck with it lol
gt96stang
take it to a muffler shop.. they shouldn't charge too much just to weld that small spot..
