Have fuel problem
US Soldier(stang 98)
Dixon IL
well right now i am getting COMP CAM's (Hot Street cams) 236/240 DURATION & .500/.500 LIFT. for my all motor 4.6, what will i need for my fuel system?
here are the parts that i am looking at right now to go with my cams. i hope you guys can tell me if i do/dont need the parts :dontknow:. Thanks guys
FUEL PUMP, INLINE, 50 GPH, POWER PLUS SERIES BBK
FUEL INJECTORS, 24LB, SET OF 8, EV6 BODY
blown98gt
you shouldn't need the EV6 body, the 24lb injectors plug directly into our cars, you should only need the injectors if you have a 1999+ model.
2nd you really shouldn't need an inline but if you are going to do it, look into the AFM Inline Pump i use it and it's a direct plug and play.
honestly all you should need is a 255lph pump and 24lb injectors
bobtsgt
yep just shop around for some 24lbs and throw in a 255lph pump and you should be fine. the pump will last you up to 400+. unless your boosting anytime soon just run the 24lbs injectors. If you plan on a supercharger or turbo down the road soon you should look for some 42lbs injectors. Otherwise just find some cheap 24s off ebay or a forum and toss them in. You may need your tune tweaked for the bigger injector as well.
