headlight promblems help
ll2none
Come someone please tell me what could be wrong.. As soon as I turn the key on the headlights come on. I've changed the headlight switch as well as the multi-position switch. I don't have daytime running light so I don't understand why this is happening. My car is a 95 gt convertible.
I would think you have a Canadian car with DRL's other than that IDK.
I guess you need a wiring diagram and a test light.
ProKiller
PA
does it come on when the key is on or only when the car is running?
toyman
If you have the DRL's the light's will come on high bean but with a reduced voltage when the ignition is in the run position. When you pull the headlight switch do the lights brighten and switch between low and high beams? If they do then for sure you have a car with the DRL's.
L
ll2none
well when i turn the key on the lights come on and stay on while the car is running... first time ive driven the car in a couple years but im sure the i dont have daytime running lamps.. if i did there would be a way to cut them off, i think... at least thats the way it is on my truck
toyman
Short of disconnecting them from the module they can't be turned off. Did you check to see what happens when you turn on the headlight switch?
