Headlight switch: pulled the plunger out
Daryl
Somis, CA
I pulled the headlight switch out with the usual amount of pull to turn on the headlights the other morning at Oh-dark-thirty and (surprise!) the plunger pulled all the way out and I'm left holding it in my hand! I was able to put it back in, felt it "catch" a bit, then carefully and slowly pulled it back out and the lights activated. Did the same slow, easy, "finesse-type" pull again the next morning, and the lights activated again.
Is this a sign that my headlight switch is crapping out? Maybe inside the switch where the tip of the plunger has that beveled edge isn't catching on the spring or bracket it sticks into? Or is this NOT a sign of a failing switch at all?
I unscrewed the gauge panel and because of the additional gauges, the panel itself doesn't pull away far at all. So, I was unable to pull the switch out without dicing and splicing all the gauge work I've just recently had done. And you guys know me.... I have ZERO electrical knowledge/experience. ;-(
shurur
Switch is probably fine.
Just the knob and its catch is tired. Salvage yard, ebay, LMR, CJPpony or a dab of PERMATEX adhesive silicone will fix it.
the knob is held on by a small spring that can eventually crack the side of the plastic housing and cause this problem. If you look inside the hole of the knob you should be able to see it, if not then look at below the switch and it is just a small half round piece.
Daryl
Daryl
Somis, CA
Worth taking a shot with the PermaTex if I might have to replace it anyway. If it works, save $$
Daryl
Daryl
Somis, CA
For whatever reason, it’s working fine now. Maybe it wasn’t pushed in all the way from the last time I had the gauge bezel off?? IDK
07GtS197
Fort Myers, Fl
If the headlight switch for these cars are like others that operate the same from other models, there is a button either on the side or bottom that will release the plunger when depressed.
maillemaker
Yes, as I recall, when you replace the switch you have to transfer the shaft.
maillemaker
Here is the one I bought from Oreilly's. No shaft.
Well, I can't remember if it was the 7 or 9 terminal switch but anyway they both do not come with a shaft.
Daryl
Daryl
Somis, CA
Mine seems to be working fine again. For no apparent reason! Maybe they didn’t push it all the way in to the “click” when they had the gauge bezel off. IDK, but it works fine now
