Headlights....
AaRoN
King Post Whore
my96gtstang said:
They aren't cracked or anything, just the weather stripping was weakly designed and fell off... There are no cracks in the actual headlight...
Ok. That's fine. I mean, put the lights in an oven or use a hairdryer to weaken the factory glue so you can pull them apart. Then use the RTV to make a new (better) seal.
B
Brian95SVT
Chesapeake, VA
see that's where yall aren't getting what I'm trying to say....
I don't want to RE-SEAL my headlights. I want to get NEW weatherstripping so it looks clean again.
I don't need to re-seal my headlights. I just wanted the weatherstripping around the lights back and flush against the car.
So therefore, I don't need the RTV
Jrgunn5150
Except you do need the RTV, because you can't get the weatherstriping seperately as far as I know. SO you either need new light's, or just fix the ones you have.
B
Brian95SVT
Chesapeake, VA
.....wow..
yall still aren't getting it..
my headlights ARE fine, no cracks. I just wanted to know if there was a place to get headlight weatherstripping.....
now i'm starting to get frustrated.... gr...
Jrgunn5150
trav_19
i know exactly what your saying man lol since i bought clear corners and my rubber seals feel of in 3 months... :hammer: :hammer: :hammer: :hammer: there is not a great aftermarket company sooo i say keep buying them and hope for a good set....
aaron is hooked on the bond between the lense and the housing your wanting the rubber seal that covers up the seals and wraps around the light to the bodyline right
B
Brian95SVT
Chesapeake, VA
yea haha that's what i want
hahah
scarface
Guest
just take it off all together bro. Lots of people just remove that little black strip becuase they dont stay on well. They are just superglued on the cheaper aftermarket lights. If you dont like it off, glue it back on :thumb:
scarface
Guest
my96gtstang said:
They broke off in pieces ahha.
What would be good to get them off??
I would try picking them off with your fingernails, maybe some thinner to remove the glue.... then you could use some buffing compound to remove the dinginess if there is any.
realitygt
ford atleast makes the weather stripping stay on... I can't say anything about the headlights leaking tho...
