Headswap and blower
navarro98gt
Has anybody supercharged there PI headswaped cars? I know that it can be done with a spot on tune but has anybody here actually have real life experience with it? Dyno numbers? Track times? I?m looking into the Mongoose kit and blower cams from MPH. Thanks :headbang:
blown98gt
I did, but then switched over to custom grind cams.. I made 600 range on pi cams and a D1sc.. I never got to run it at the track like this but the MPH cams are really nice
N
navarro98gt
I?m assuming that wasn?t on the stock block and internals. Anybody do it on stock block and internals??
97stanger
i dont know man. There are plenty of safer ways to reach the limits of these stock bottom ends without even touching the heads. I'm at 400/400 with stock NON PI heads and only stock PI cams
N
navarro98gt
Yea but i don't really want to swap the PI heads back to NPI's. By the way, what converter are you running?
97stanger
ohhh, you already have PI heads on the car? Sorry if I missed that.
I run a BC-Auto multi disc lockup 3600 stall
chris98gt
Im sitting on 376/360 rwhp/tq with my pi head swapped car and stage 2 npi cams plus the stuff in my sig. I'm using the factory thickness head gaskets and running 11* timing on 93 octane. I've been running it this way for almost 2 years now and best 1/4mile was a 12.27 @ 112mph last november.
97stanger
Nice setup there man. What kind of rime/tire setup you running there?
sorry to threadjack
N
navarro98gt
Just what I wanted to hear. Any particular reason your running npi cams??
sorry to threadjack
Don't worry about it man, I'm also curious as to what kind of tire he,s running, and his 60' times.
N
navarro98gt
Nice, I've been in contact with Darrin @ B.C. You have any problems with your converter? I've herd that they have problems locking up at WOT. I'll most likley be ordering a 3800 stall speed converter this Friday, I've been debaiting between B.C. and Dirty Dog.
karrarararararar
don't want to thread jack either but how much boost are you running with your setup?
DropTopPony
South Jersey
I'm about to do it in a few weeks. I have all the parts to build my forged SB but don't have the extra cash to get the Teksid block properly line honed bored etc so i'm throwing my blower on. I already have Fox Lake PI heads and i'm gonna throw in my VT blower cams and see if it lasts all summer. I'm just gonna keep it at 6psi and not push my luck. My friend ran his with 8psi and a Vortech for 3 years with out an issue. He had a good tune and always ran 93 octane.
chris98gt
I'm running 15x6 in the front and 15x8 prostars in the rear with m/t drag radials. Best 60' was 1.72 on that 12.27 pass. I didn't expect to put the blower on this setup at first so I did the head swap and npi cams before I even had the blower. I then got a great deal on the whole procharger kit and decided to try my luck.
N
navarro98gt
Well keep us posted on the results. I'm curious to see what kind of numbers that combo will produce. Do you know what numbers your buddy put down?
97stanger
I see about 14psi, intercooled. With the blower cams in I expect to see about 12psi.
DropTopPony
South Jersey
I would probably guess i will be in the 350 range with the small pulley on and very soft tune. My friend was making about 330rwhp with a basically stock PI swapped car and Vortech base kit. I know he wishes he still had it.
