Help… need a 94-95 5.0 water pump bolt Upstate SC
DirtySC
Hi All! Upside to a lay-off is time. Just started to work on my 95 Cobra that’s been sitting in storage for the past 10+ years. Parked with a leaking water pump. Thanks to member “Saint” for the good write-up. That said the previous owner used one shorter non-oem bolt that is too short. Anyone in the SC upstate or Atlanta area willing to sell me the correct bolt? Plan B is the Late Model Restoration set.
Thanks!
Terrorist 5.0
To find a singular bolt would be pretty hard. I would say your best bet is start searching junkyards if you really only want that one bolt. If the water pump has been replaced and you don’t have to fight with corrosion, I would suggest just buying the bolt kit from LMR. Saves you headache in the future, and saves you lots of time. I don’t know of anywhere else you can buy the bolts as a set.
RAU03MACH
NEW MEXICO
do you have a nut and bolt place that sells nothing but fasteners
take the studded bolt with nut off the pump take it with you match it up
weendoggy
If you know what length you need, check out Bolt Depot. They have lots of items and sell by the piece, not bunch. I get most all my fasteners from them.
STITCHSCREWW
