Help!!! 94GT 3k idle
BCAV5
I have no clue!!!!
Car ran fine all day. I went to get dinner it would turn over but not start. When it finally started it was surging at idle. Now it will idle at 2-3k. It will drive but as soon as I push the clutch in rpms jump to 2-3k and stay until I give gas and then they go up.
if anyone is in the Baton Rouge area and would be able to come look at my car it would be greatly appreciated.
they are under the hood but all mine have been changed or moved. The vac tree is on the drivers side and there are some under the upper intake as well
apsmith49921
Take a bottle of carb cleaner and start spraying around the intake if the idle surges theres your leak. You can also take the car in and have a smoke test done.
Sent from my SM-G955U using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
You can buy a cigar and easily do the smoke test yourself. Pull the vac line from the brake booster and start blowing smoke into it. When you see smoke coming out you’ll know where the leak is.
apsmith49921
I should have asked if he was a smoker... this is exactly what I did lol.
