help fast
dave1989
i pulled my valve covers to replace the gaskets and in the procees i managed to break off most of the vacume lines and the egr tube. my question is i already have removed the smog pump and and the line i broke off are in the same lil harnnes that runs to some type of vaccume box in the fender on the passenger side could i take the bos completely off and just simply plug the intake vaccumes and remove the egr valve and if so houw would the car run
birel21y
I dont run any of the vacuum tubes running into the fender, but then again, i dont run a EGR either. My car runs fine. If you want to be safe, just go buy some rubber vacuum tubing and fix the broken lines.
dave1989
well i did anyways and goin in the mornig to get a cap for the header ill let yall know how it does
Staff online
