Help me find some machined valve covers that go over trickflow heads
I have had some cheap stamped valve covers for a while now. They are ok but they do not seal all that well and I would like to swap them out when I install my polished intake(hopefully soon). I need a new machined aluminum set with out any graphics/logo's on them that will clear my trickflow TW170 heads with 1.6RR's as well as get around the alt that can be a problem. Anyone know what height they need to be over to clear the rockers, but need to be under to fit under the intake?
ProKiller
PA
I have these:
http://www.americanmuscle.com/moroso-fab-valvecover-9495.html
Yes they are expensive but they fit around the alternator and look amazing.
Yea they do look nice but I am planning some custom stuff to them that would not even get it up too that price. Wish I could find a height on those...
ivan12
check out jegs.com I think I saw them on there, might have the dimensions in the specs section
mikey94gt
Factory Fox covers get my vote... they are aluminum. With a little grinding they will fit over a roller rocker pretty easily, ive done it a few times. Trick Flow's rounded ones, the ones that come in the top end kit, are pretty nice and not too much $$, they dont have any holes either, and the logo could be milled off pretty easily.
the fox idea sounds interesting, didn't thing they were aluminum. I just need something better then the stamped ones I have not that leak a little and want to get a custom design put on the top of it.
ProKiller
PA
the moroso ones are like 3.5" tall if memory serves right when i was looking into putting a baffle in.
mikey94gt
The only thing that might get ya with the fox covers is where the oil fill neck is, its sorta close to the IAC on a SN95. Grind out the baffles and you're good to go!!
95 Drop top snake
Birmingham alabama
[/IMG]I have fox valve covers on my car and they clear my scorpion roller rockers and their huge!! All I had to do is remove the baffle and do some minor grinding. And to solve the filler neck issue I cut the neck in half and got a 45 degree bent radiator hose and cut in about 6 inches long then shortend the top half of the filler neck and tied it all together with hose clamps works well doesn't leak and looks clean. Not a very good picture but the best I have u can see how far the full is from the iac valve now, we're it would be right up against it.
Clean90GT
Ttocs , bang for the buck you can't go wrong with a set of fox vc's. worst case , you buy them and resell them for what you have invested. There cheep , offer some good options and will clear most rockers pretty easy. You can paint them to match , powder coat them or they polish up really nice and pretty easy. I snagged mine on craigslist for $20. Don't pay over $50 and at that , it better be what you want.
I need to anodize them and then will have a design laser etched into them. Just concearned now with the EGR clearing it really
Clean90GT
Where are you getting the laser etching done? I need to make a cover plate for my tubular gt40 and would like "5.0" etched in to it.
Clean90GT
There's a set of fox vc's in the classifieds on here for $20 in primer. Let me know if you don't snag them , I'd like to get a set to polish and sell mine once there done.
