Help picking out overflow bottle
ivan12
When I re-did my engine bay I chose to relocate the CCRM to the fenderwell and get rid of the coolant bracket all together. Now I've narrowed down my choices to 3 bottles, 1 of them is the fox bottle that will let me reuse the stock sensor, the other 2 are rectangular pieces by Canton. They're all similarly priced, it's just a matter of preference for now. Just looking for some input, below is a picture comparing all 3 and a pic of the engine bay the bottle will go in.
ProKiller
PA
linky no worky.
since you went through the trouble of hiding the CCRM, you should just hide the overflow too.
ivan12
ivan12
Fixed.
That would be nice, but at this point the space in the fenders is already very limited
BOS-94-003
I'd pick the one that suites your needs the best so technically you'd be picking. If you want to keep the stock sensor go with the fox. If not, go with the one of the other two that best fits in the space you've designated . 80-211 looks like it would fit nicely in the battery area (assuming thats where u want it). However, it might be too square in which case you'd need the 80-201 to keep it away from your fancy p/s pump. Looks like you have it narrowed down to the 3 and need to make your final decision. Maybe base it on customer reviews because no one on here will be able to tell you which one you like.
95opal
linky no worky.
Get a cheap one from summit. $100 on an overflow is a waste of money IMO
mount it in front of the rad.
ivan12
ivan12
Thanks Musturd, it's 99% done can't wait to start her up.
@opal, That was the original plan, and that's what I have. The problem is the intercooler took all of that space so now I have to mount it in my bay and there's no way I'm going to put that plastic tank in with all of the work and money I've spent making it look respectable
thanks toyman! not trying to thread jack or anything but can you tell me what it does? im trying to learn what all this initials are everyone uses lol
ivan12
ivan12
I went with the one Castine917 mentioned from Jegs, I couldn't use it in the spot I had hoped for but the other ones wouldn't have worked there either.
ivan12
ivan12
Stock replacement from rockauto, I believe the brand is four seasons
