Help - transmission sounds like a grinding wheel
Ronin
96 Mustang GT manual transmission noise
It has a short-throw shifter, and I've heard a noise like this before... the shifter just needed tightening, but that was less than 1,000 miles ago. This is a lot worse than that, and is constant through all gears...the old noise went away if I put my hand on the shifter, and I only heard it in 5th gear. Goes away when in neutral and coasting. I'm taking it to a mechanic soon, just thought I'd look for thoughts.
Willis_98GT
DFW Texas
mine has a very slight wine to it and always has since i installed it, and has survived.
when i say survive i mean it.. btw
i think your good, is their any driveablilty problems?
Ronin
Ronin
occasional grind if I shift too quickly during the first 5ish minutes of driving, but that's it...though it's hard to tell if performance is suffering...it's all suffering from the heat. The big hair drier under my hood doesn't like 108 F. :sad5:
Ronin
Ronin
BTW, all my sounds turned out to be a bad wheel bearing and a rear end in need of rebuild. Now it sounds great.
dirtysnowball302
well i cant really hear it..but did you put a new cluch in? it could be your pilot bearing... i mean idk the video dont help. Only when you shift? or what
Ronin
Ronin
Per my last post, it was an issue with the rear end (and a bad wheel bearing)
