yea it's free replacement. and easy enough to do
x182dan said:you bought a dizzy from autozone thats a risky move. Anything electrical is crap from them. However it does sound like HGs mine did the same thing when they went except I had fluid coming out of the over flow because it was creating that much pressure.
tommybunz said:try the ignition module on the pass. fenderwell
DESERTCOX05 said:Did you disconnect the computer when you pulled the engine?
If you did, look for bent pins inside the connector.
If you didn't, look under the hood for a pinched wire or a bent pin inside the connectors under the hood.
Electrical probs can be a PITA. good luck
tommybunz said:using a ohm meter check ground at MAF sensor pin B blk one. then disconnect battery put new fuse in and see what happens.
