High beams not working...
scottyp
My brights aren't working and I can't get the car to pass state inspection until I get it fixed. The headlights and both blinkers work, I replaced the bulbs and the fuse is good. What else should I check for? Thanks
Sent from my SPH-L900 using Tapatalk
DeepList
Administrator
Auburn, IN
A couple questions before we go any further:
- Do you have HIDs or just stock bulbs?
- When you try and put the high beams on, does the high beam indicator light up on the cluster, or no?
- When you pull the multi-function switch towards you (as if you were going to flash the highbeams at somebody) does it do anything?
don't check THE fuse. Take my word for it go and check EVERY fuse. Its amazing how often the fuse blown has nothing listed with the problem at hand according to the manual.
Do you have a voltmeter/test light and know how to use it?
scottyp
scottyp
Yes I do. I'll check them all again here in a bit.
Win
Kennesaw, Ga
Might have some dust in the turn signal/high beam knob.
these.
senior001
Staff online
