how bad is the chances of spark plug blowout?..
yellow tang
Wisconsin
I picked up a excellent condition 2004 gt conv. Has 70k on it. After fixing the top to go up like should ( bad line)..I think it is ready to drive. newer tires on..serpitine looks excellent..no dash lights on..I want to make 3 or 4 trips this summer to a city to visit friend and guessing about 250 miles each trip..there/back/plus extra. Do you think this car will be pretty reliable? I heard the 4.6 had a bad issue with plugs blowing out of hole? But.. I also heard 4.6 is known to get high miles so this plug thing common? I'm almost afraid to drive it far after reading that. I won't be driving hard ever..just cruising and in town trips
RAU03MACH
NEW MEXICO
4.6 expedition my buddy had, there were not enough threads in the spark plug holes
his were always popping out
i put a set of motor craft in still popping out
i ended up installing another set of 4.6 heads problem solved
Y
yellow tang
Wisconsin
Thanks on reply's! good to hear... P.S. I realized after posting this that I put it in wrong place. I re-did it in the 2v engine specific section..I couldn't figure out how to delete post here in this section. Guess glad I didn't because now I have my answer!
RAU03MACH
NEW MEXICO
i will say this use motor craft plugs use torque spec
you will be fine
if those plugs are factory originals your good and it would have done it a long while back
07GtS197
Fort Myers, Fl
Problem is, the stock heads only have 4 threads but you should have the revised 8 thread heads. They’re not immune to blowing plugs but they’re less prone to it.
Most of the issues come from the f series and expeditions because the rear plugs are harder to get to so they’re not torqued as well. If you’re concerned, put a torque wrench on every plug and verify they’re at 13 ft lb.
Exeter Ontario
I had a 4.6 truck blow a plug and it broke the inner manifold , a costly repair but a 4.5 is a different horse
