How much do heavy duty U joints cost?
Jrgunn5150
Define heavy duty? The stock u-joint is a standard 1310, the best one avalable commonly is the Spicer solid u joint at 20 bucks, but CTM cryo treated bronze roller's run 200 bucks, you can also substitute any amount of other ujoint's....
J
justinschmidt1
Nothing serious, just a step above stock would work.
Im pretty sure my u joints are bad cause im getting this loud almost banging like sound when I go into reverse....thats supposed to be a major sign of u joint failure.
BigTang
I went w/ the spicers and it was $60 to have them installed. To my knowledge they are a sealed type that you can't grease.
SRT Handz
will a standard Transmission Shop do the install of the U Joints if i bring them the Driveshaft? If so how much do they charge (Ballpark Figure)?
J
justinschmidt1
Why would you even do that?
If you have the driveshaft off installing the u joint should be like two steps
Remove the little clips with needlenose pliers and bang the joint out using a socket and a hammer.
Jrgunn5150
Yeah, probably want 50 bucks, all it takes is a vice though.
SRT Handz
justinschmidt1 said:
Why are you even worried about your u joints handz?
Because they old and worn and when i got my clutch installed my Tranny dude said they needed to be replaced soon. Its cheap so might as well do it now.
J
justinschmidt1
Ah...gotcha.
Mine sound like my driveshafts getting ready to rip off anytime soon.
JerZeyStangz
Northern NJ
What are the symptoms of this, just curious...On cold days when I put the car in reverse, then right into drive it makes a creak noise, but when its warm it doesn't do it at all.
J
justinschmidt1
From my understanding the u joint will be loose....so going from drive to reverse you should notice almost like a metal on metal banging and going from a dead stop you can hear/feel it a bit.
Also, when coasting at highway speeds and letting of the gas you might feel vibrations or shuttering.
J
justinschmidt1
Just in case anyone is wondering the u joints were a breeze.
I lifted the front of my car a little less so the trans fluid didnt even leak out.
Popped the old one out with a hammer, new one in.
Threw the shaft back on and I have no banging noise now.
Woohoo
1quk50
i have the vibration at about 70 mph... but my u-joints are not loose... what could that be?
