How to I.D. a PI Intake
delling3
Sterling Heights, MI
I have a 96 GT, which I recently purchased. My understanding was that the NPI intake had a plastic crossover, while the PI intake was a aluminum crossover. My intake has an aluminum cross-over. Does this mean the intake has already been swapped with a PI one? Were NPI intakes made with an aluminum crossover? I know the PI intake has much longer intake runners, but I don't think you can see that with the intake installed on the engine. Are there other visual clues that I can look for? Don't want to buy a PI intake if I already have one . . .
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Some npi intakes have aluminum crossovers. Grab a picture of the top of the intake and post it here. Look at the first runner behind the aluminum crossover, if it goes to the drive side it PI, if it goes to the passenger side then its NPI.
Defiant
CT
Look at the first intake runner (closest to the front), if it goes toward the driver’s side it’s a PI intake, if it goes to the passenger side it’s NPI.
PinkieT
Cleveland
Also see if you can find Ford markings. Dorman makes replacement intakes for PI heads but don't flow like the Ford intakes. If there is a PI Dorman on there, just swapping for a Ford piece will give you some added power.
07GtS197
Fort Myers, Fl
Simple way of telling if its a Ford intake or not is looking for holes on both sides of where the plenum bolts to the intake. Its solid plastic on Ford intakes but in every replacement intake Ive seen there is no plastic there between the runners for cylinders 2 and 3 and 6 and 7.
