How To: Rear View Mirror Swap
MustangChris
Aurora, CO
How To:
Swap Exterior Mirrors.
On the export models heading to aust., jap., and eur. of our cars, they had a few minor changes. one of which was folding mirrors. This change came to the united states' models in 2003 with the Terminator Cobra.
OEM 1994-1998 Mustang Mirrors:
2003/2004 Cobra Mirrors:
1994-1998 Export Mirrors:
Here is a step-by-step how to on how to change your plastic, mirrors to the metal, folding cobra mirrors.
Tools NEEDED:
11mm open end wrench. (or simular, 7/16 will work if you only have standard tools)
Long Flat head screw driver
Tools that HELP:
Long needle nose pliers
ratcheting box-end 11mm wrench
Magnet on a stick
Partner in crime.
Step 1:
open the door and roll down the window
Step 2:
Use your flat head screwdriver to push the interior molding up, toward to the ceiling. DO NOT FORCE IT. It will *ONLY* more roughly 1/8"
Step 3:
Use your flathead screwdriver to pry the interior pannel out, toward you, to remove it.
Step 4:
Use your flathead to remove the door pannel that you pull on to close the door.
Disconect all wiring and place the door pannel in a safe location, as to not step on it.
The "Handle" part makes a good spot to store the extra parts.
Step 5:
inspect the interior of the door to ensure the water gaurd is in good condition, all wires are in good condition, and nothing seems out of the ordinary.
Step 6:
Disconnect the wiring to the mirror. Pull the pin out (towards you) that holds the wiring to the door.
*note: you can *slide* the wiring *up* off the holding-unit to give you extra "playing room."
Step 7:
unbolt the mirrors, try not to drop the nuts into the door pannel. a ratcheting box-end wrench will make this 100times easier.
Note: if doing this by yourself, leave the top bolt for last. unbolt it while HOLDING ONTO THE MIRROR.
if doing this with a partner, make sure tehy hold the mirror firmly.
Install is reverse of removal. Proceedure is same on both passenger and driver side mirrors.
TQ SPECS:
1996 Mustang: Tighten to 11-13 N-m (8-10 Lb-Ft)
2003 Mustang: Tighten to 12 Nm (9 lb-ft)
Now you have awesome cobra (or if youre lucky export) mirrors!!
SRT Handz
Nice writeup chris!!
You might wanna change the tools needed from Standard size to Metric because our cars use metric nuts & bolts.
MustangChris
MustangChris
Aurora, CO
Thanks Handz,
Fixed :) also added final TQ specs for proper install.
TQ specs are for 1996 Mustang and a 2003 Mustang, they may have changed on other years.
alleghenyamerican
