Patron022
- Joined
- Sep 23, 2010
- Messages
- 115
- Reaction score
- 0
Had the idea of spray painting the anthracite bullitts black to match and make the look a bit sicker.
Supplies needed:
*Aircraft Remover ( Paint Stripper ) - Wear gloves and also try not to touch this since it will burn and irritate your skin.
*A brush
*Metal bowl to put paint stripper on.
*Primer (In my case I used Ace RUST STOP Primer has 15oz and it was only $5 dollars)
*Color of paint you want to paint (I used Ace RUST STOP black gloss paint also 15oz and $5 dollars)
*Masking tape.
* Step 1 - Remove wheel and clean with degreaser and also take off center cap.
* Step 2 - Add paint stripper to wheel
* Step 3 - Wait 15 minutes for paint to strip. Some sanding and more prep might be needed depending on how good the paint stripper is.
* Step 4 - Tape up and paint ( Painting the lip is tedious work and takes a while :BangHead:.
*step 5 - Paint ( I suggest 2 coats )
* Step 6 - Add gloss to protect paint and unmask tape.
Once dried good put back on car and admire :headbang:!
I also paint stripped the lip and will be wet-sanding and polish it to really shine. Hope this helps out
ccasion14:!
Supplies needed:
*A brush
*Masking tape.
