I love t-45s
Willis_98GT
DFW Texas
was driving eariler. and no third or 4th. their is no play in the shifter going up or down. i could blow the shifter into 3rd or 4th. but still have 1st 2nd 5th and rev and they shift smooth as butter.. any suggestions..
reivaxtorres
yeah, exactly what happened to me. you broke the 3-4 shift fork. dont worry, its only about $40 or $50 from ford......but the labor is gonna cost you. cost me $600 for labor, and $42 for the part. :tickedoff:
Pennywise2
Don't feel bad because the TR-3650 have worse problems.
Did you ever powershift your T-45?
W
Willis_98GT
DFW Texas
nope, don't powershift. and really lately haven't been getting on it at all.
it was wierd, just kinda gummed up coming out of third and that was it.. is their any kinda stronger forks i could put in there so this doesn't happen again? or some sort of a rebuild kit with stronger guts?
orrrrrr is the t-56 swap really that expensive?
reivaxtorres
there really arent that many upgrades available for the t-45, but there are some companies that make stronger shift forks. cant remember who it was tho. but other than the shift forks and the synchros, there really isnt an aftermarket for our transmissions.
if you can find a really good deal on th t-56, i would rather go with that swap. i figure (depending on the deals you find) about $1000-$1500 for a t-56 swap.
or....you could try to find a used t-45. thats what i did. after i snapped the shift fork, i got that replaced, and about 3-4 months down the road same thing happened except it was stuck in 3rd gear now. so instead of trying to get it fixed again and go thru the same problem (I also had the pop-out-of-reverse issue that the t-45 is known for), i found a used one for $700. bolted that one on and so far no issues.
W
Willis_98GT
DFW Texas
theirs a dude that has one local that came out of a 97 cobra. and says it'll work with my car, would i be good or would i have to change the bell or something?
or should i just go in and change the forks. you said that you can get them from the ford dealership for cheap. you just take the top off the transmission or something rather right?
Jrgunn5150
The Cobra uses a different tailhousing and mount.
The labor is so high, because of the integral bellhousing. It's a front loader trans, so everything comes out the front. You'd be better off to swap your tail onto the Cobra unit, and start saving your pennies for something better. There's a reason I refuse to touch a T45.
Oh, and stronger shift forks are available in the 99 unit's, you can get them from Hanlon motorsports.
realitygt
I think mine is going out :/ it crackles when it bogs and lately randomly it doesn't want to go into 2nd then i let the clutch out and push it in and it'll go right in ...
i'm wanting to do the t56 swap cause there are so many 03 cobra's around here that are switching to auto's right now ... idk why.
Jrgunn5150
Because unless you have some kind of small dick syndrome, auto>manual for drag racing, especially a 4r70w vs a T56, that trans is not optimum for any drag racing, and the Cobra version is the suckiest of them all.
realitygt
i had no clue the cobra's t56 sucked lol
i haven't looked into it at all so idk.
Jrgunn5150
They don't suck for you, the ratios are kinda lame for pretty much any racing, and the kind of power they put through them, they are weak at that level.
justinschmidt1
Yea, I really hate talking to anyone about my car cause theyre like o man, your car would be so much faster if it was 5 speed
like wtf...you dont know shit
5 speed mustang trannys suck and break all the time.....4r70w is a way better tranny for racing if I wanted to get a stall and set it up for drag racing
it seems like everyone has small dick syndrome
Banging gears is fun...but autos rule the strip
realitygt
cause you can't shift as fast as an auto. but with an auto you have to set it up specifically for drag racing like a high stall and shift kit or whatever you auto guys do lol. and getting a stall that maximizes your potential isn't going to be the best choice for driving to and from the race track, plus you couldn't auto x very well .
I mean if i had an all out drag car i'd do an auto trans cause they're better for that. but imo i'd rather have a manual so i could not be limited so much :dunno:
Jrgunn5150
You auto x? no, of course not. I don't know how your limited with an auto, I can make a 4r70w my bitch, hell, you can even put paddle shifters on one, and it'll still shift quicker than any wanna be working a clutch pedal.
realitygt
if you have a drag oriented automatic then it limits you to that. but if you have a stick you're not limited to just drag racing. you see what I mean? I guess i'm just coming off wrong or not saying what i want to say right.
and to be the devil's advocate ferrari doesn't even make a stickshift anymore. what's that tell ya?
Jrgunn5150
Ferrari owners are toolbag's that can't work a clutch :hammer:
What your saying is somewhat true, you wouldn't run a 4500 rpm converter to auto x. However, a car that could use that much converter wouldn't auto x anyway, lol.
reivaxtorres
yup, the tailshafts are different. you have 3 choices with this tho, and ive done them all except #1:
1) like JR said, you can just swap out the tailshaft between the GT and the cobra transmission. its a rather simple process, all thats involved is removing the shifter, using a punch to free the shifter shaft (no idea what its really called, but its the part of the transmission thats visible when you remove the shifter....i have a picture of it somewhere, but i gotta look for it), then you just unbolt the tail housing and swap them out. kind of the easy route, since you get to re-use everything from your old t-45
2) get a little creative, and use everything the same as the GT, just go to a scrap yard and get a 1/4" thick steel plate and make an adapter for the difference in the location of the GT mount and the Cobra mount. i did that, and it worked fine for years. here is a picture of my custom made mount:
3) you go to a salvage yard that has a 96-98 Cobra, and you buy the "Transmission Crossmember Mounting Brackets". on the GT, where the cross member mounts, there are brackets that are welded onto the frame/body of the car. if you look farther down that same part of the car, you will see a pair of holes already drilled in. these are made for the cobra. on the cobra, the brackets they use for the crossmember arent welded onto the car, they are bolted onto the car. i got a used pair off a 98 cobra a few months ago just for the hell of it, and they only cost me about $50 from my local junk yard. the only problem with them was that the location of the cats (aftermarket) was now hitting the cobra crossmember. i modified the pipe a little and it fits like a charm now.
or....you could just have your transmission rebuilt by an expert. the t-45 is labor instensive, and its a little tricky to work on so make sure you take it somewhere that has had some experience in either the t-45 or the tr3650.
EDIT:
i just found a diagram a friend of mine from ford gave me awhile ago. the parts from ford are discontined now, but it shows where the crossmember mounts to the brackets that mount to the frame on the cobra are located:
g_dogg
I don't know much about tranny's.this is what it says in the description:
This unit has 26spl Input, Latest 3/4 Fork, 3rd metal spacer, HD 1/2-3/4 key kit,
carbon fiber synchros, HD t/o tube or HD shorty tube
$1390.00
