I mixed up my fuel ines.
Trevor57
Which is the feed, and which is the return on the fuel rail? I know the larger diameter hard fuel line is the feed, but I don't know which fitting on the fuel rail to connect it to.
T
Trevor57
The car does not have a key anymore. It also does not have the stock type fittings. It is the stock rail though.
castine917
wyoming, mi
by cycle the key he means cycle the pump to see where fuel flows out. with the stock rail you lean over passenger side fender to perform work at fuel lines? which connection is to your left? that is what he means by left.
T
Trevor57
LOL that is exactly my question. I asked which one is feed and which one is return. So which one is on the left? Feed or return?
i'm pretty sure the large one is the feed, the smaller one is the return. The smaller one should hook up to the FPR (pass) side.
