I need help my car is leaking Oil??
98mstanggt
98mstanggt
Louisiana
It cant be the oil filter thats leaking because it wouldnt be all over the steering shaft, or my LT headers. It is about that time for a oil change if that mean anything. Also the last couple of days since i put some more oil in the engine i've been riding around just fine went out yesterday rode around for about 45 minutes still no leak or anything even at start ups no leaks im confused now :dontknow:
100 a set is what i meant. lol...
and as i said, my steering rack looked like that too, but thats because I suck at taking off my oil filter.
badass98svt
Like I mentioned earlier...When you start the car, is it still warm from the last time you drove it (within the last 10-12 hours).
Why do you say it can't be the filter? It's right above your rack, isn't it? It is on my 4V
badass98svt
yes it would. As you drive, all the oil blows back and gets everywhere.
+1. i had the same problem with my valve cover... thought it was me just missing on the fill-up, but there was a tiny leak on my drivers side valve cover... it would turn into a full drop when sitting, then when i would drive away the air would just dispurse it... i thought that it was something major because it would smoke so bad... but it was litterally nothing...
98mstanggt
98mstanggt
Louisiana
I dont know whats going on i even drove to Pensacola, Fl and back which all together is about an 12 hour drive no oil leak or nothing. I guess i'll stop worrying myself about the oil and just keep my eyes peeled pretty sure it will leak again but i thank you guys for your help at least i gotta an idea of what to look for next time. :grin:
windsordeath
Hey, any of those things can leak and with you going down the road can blow the oil back on the headers...Maybe I missed it in the thread but have you had a oil consumption issue with the engine? Also one thing that is overlooked is I've had oil leaks from the front cover right where the block,head andtiming cover all meet..and that is right above the Oilfilter/coolant adapter...
You ever find yourself near pcola again just PM me the night before and swing by..we'll put it on the lift and see if we can find something...cool?
badass98svt
Dude, this is my 3rd time asking...
When you drive the car (with NO leaks), was the car warm still from the last time you drove it?(Did you use it in the last 10-12 hours)
98mstanggt
98mstanggt
Louisiana
LOL my bad no everytime i drove the car wasnt warm. I let the car sit for about two days before i actually drove the thing cause i was scared so that def was a cold start.
badass98svt
Hmmmm...That IS starnge then.
My guess is it's coming from the filter area.
When you cahnge the oil, make SURE the bung that the filter screws to is TIGHT. On my cobra it's a 1/2" allen (or metric equivalent 12 or 13mm)
justinschmidt1
badass98svt said:
Let me ask you something. When you took it out and it DIDN'T leak oil, was the car still "warm"? Did you drive it in the last 12 hours or so?
I had a BAD oil leak in the exact same location. It was my oil cooler gasket. It would leak with a very fast pour out from the area with a cold start. It'd leak about 1.5 quarts.
If I started the car within another 10-12 hours, I would have ZERO leak. Not even a drop.
I don't remember if the GTs have the oil cooler too, but I have the correct gasket FS in the classifieds currently.
Listen to this guy.
I have a similar problem....car only leaks when its cold. Its the gasket for the oil filter adapter
badass98svt
justinschmidt1 said:
Listen to this guy.
Not sure if you need it, but I have that gasket here and don't need it.
It's actually in the classifieds.
GDTrumbo
Nashville, TN
This is something I have often wondered. Do the '98's and after not have this filter adapter? Mine does not have this item.
Is this a Windsor blocks do and Romeo's don't kind of thing? Teksid iron blocks?
GT
98mstanggt
98mstanggt
Louisiana
I dont know if this retain to the oil leak but when i start my car from a cold start it makes a weird squeaking noise like its coming from acc drive belt or something idk but its annoying and it start happening right before the oil leak/still happening
98mstanggt
98mstanggt
Louisiana
badass98svt said:
the squeek is most likely a tensioner pulley/ alt pulley
How can i get rid of that noise its annoying/loud...........But yeah still havent seen no oil leak yet
