i need help!!! please!!!
RelapsedGT
ok.. at first my car was runnin like crap like the injectors or somethin was clogged.. i ran a couple tanks with fuel injector cleaner in it and it didnt do n e thing.. so then i thought maybe im fowlin plugs.. so i checked the plugs that i put in about a year ago nd the were not even burnt or anything.. u could still c the white.. at first it seemed like it was runnin better but then it ran like crap again.. i can drive it but then when i get up to around 3500 rpm it starts boggin down nd it kinda feels like it does when u r hitting the rev limiter.. i really need help.. i cant stand it bein like this nd i dont want to mess it up even more by drivin it.. can n e one help me.. i would really appreciate it.. what do u guys think it could b? thanks guys
Red96GT
Does it idle funny?
and next time it would make it easier if you typed out words like "be" and "and". ;D
cmher18
Fuel filter/wires/spark plugs
I would due the fuel filter first mine did the same thing. I put a new FORD fuel filter in and was good And its cheap and easy
R
RelapsedGT
sorry about the spelling.. i forgot to mention that i did put a new fuel filter on it. and no it doesnt idle funny
97vertstang
check ur firing order and look for any vacuum leaks???? do u have any engine codes??? check ur air intake tract, check ur distributor cap and rotor , look for any leaking fluids, any vacuum hoses broken,??? spark plug wires, condition?? timing??we need more info......
Teal_Beast
make sure you dont have a plug that is burnt or melted, aka resting on a header.
Spyder
I had a similar problem when I had my 95 gt. It ended that one of my cats fell apart and was blocking the exhaust. Does you exhaust sound choked at all when you hit that point where it stops pulling?
TxCobrA98
check your vacuum lines.. you may have a hole in one of them.. they can be hard to spot but i believe you can take it somewhere and they can run a test on it and find it.. im not exactly sure though.. does your car vibrate real bad at idle? any noises that your car makes that seems to be going along with this problem?
