i need to know ASAP!!!
miss2slocoupe
Canton, Georgia
so my ac compressor seized up on my car and is beginning to make a horrible noise, so i bought a used one off ebay and in the ad is said a V8 one and they sent me a V6 one... now my question is, is there a difference between the two? can i use a v6 compressor?
Thought it was descent amount of work to put a used one back in....
Was that the problem you had leaving the show?
miss2slocoupe
miss2slocoupe
Canton, Georgia
3.8 and 5.8 use the same compressor? If it does not work let me know I got a spare you can have free.
thank you :)!
ac is overrated honey. but gotta keep you cool in GA so good reason to have it good luck
yes true ive had many cars without it but when its your DD and it 100% humid out, it nice to have LOL
its on my 95, not the cobra, still have took it apart
You have to replace your low pressure liquid line and accumulator too.
why do i have too?
mustangspartan
MN
The whole system is a closed system the accumilator takes the moisture out of the system. If left to exposed air it will start to absorb the outside moisture and not function properly and kill your system again but this time there will be more damage. Im not sure about replacing the low pressure line but if there is anything in the system now it might be a good idea to inspect all harware and clean before reinstalling anything old. Also if there are any filters replace them. Please do replace it it will save you in the long run.
http://www.automotiveairconditioningrepair.com/car-ac-accumulator.html
Im also doing this in class right now and being trained/certified for both r134/r22
Raffaelli
All the metal shavings of that shelled compressor will be in the lines out of the compressor, the condensor, and the orifice tube.
(Im not sure if the orifice is removable or its built into a liquid line)...
But yea, AC system will need to be atleast completly flushed or replace all those parts.
It sucks, but the compressor spit alot of crap into the system. If you just swap compressors, its probably not going to live very long.
miss2slocoupe
miss2slocoupe
Canton, Georgia
ok gotcha! thank for the help everyone :)
well i didnt say anything about metal shaving... i think your talking about my other thread but that was with my 03 cobra... but this sounds like a freaking head ache! ugh.... but it needs to be done right
rz5.0
Great state of TEXAS
The orifice tube is built into the low pressure liquid line. Thats y you have to replace. It should only be like 15 dollars and accumulator like 30_40. Dont install till your actually ready to gey tje system vacuumed and filled. Also need to add oil to everything.
