I need to know the height of factory 93 5.0 valve covers. I need some to clear a
hmeracing
I need to know the height of factory 93 5.0 valve covers. I need some to clear aftermarket roller rockers
Addermk2
Re: I need to know the height of factory 93 5.0 valve covers. I need some to cle
stock valve covers don't clear aftermarket roller rockers...
and fox valve covers dont clear the alternator on an SN
H
hmeracing
LAFENATU wrote "The easiest way to do valve covers is look for 1994-1995 Cobra valve covers or Fox valve covers fit if you remove the baffle on the passanger side."
so are you saying this info is incorrect?
Addermk2
fox valve covers will hit the back of the alternator on an SN-95.... end of story.
as far as removing the baffles... go for it if you really want to. But you can get valve covers that DO fit for really cheap online.
fox valve covers did not work for my car, neither did my stock (cobra) valve covers
Paul
Yes they do. Just remove the baffle and grind in two small places.
I thought they did?
Addermk2
I thought they did?
unless my car is just a piece of shit, and loves giving me problems...... :crying:
El_Diablo
hmmm, i wonder if anything would clear with my s/c setup..... i would really like to get new 1.6 or 1.7 rockers for a quick power gain but i would hate to have the fitment issue pop up when its time to put everything back together
Paul
Well, I have stock fox valve covers on the motor I'm building for my notch with 1.6 roller rockers and they clear just fine - I just took out the baffle and ground them down in a couple spots. As far as the alternator fitment - I'm not sure and would need to check.
Paul.
94GTcobra
Im still using my factory valve covers and they clear fine with my 1.6 rr and my cam. I just put a double gasket and your set, there's no leaks either.
Jerry santos
