i think my CCRM went out
MuscleInc1320
so i think my ccrm went out on my 94gt. i want to go to the junk yard to get one, but i need to know what cars i could get one from. Do i have to get one only from the same year mustang?
CC'S95GT
Hampton ,Ga.
what isn't working to make you think the ccrm is bad? just gotta make sure.
94/95's should be the same.
Ford dealer should also be able to tell you whish ones are interchangeable.
GTStang96
Yeah make sure you figure out if it really is the ccrm because I thought mine went out too
and I ended up going out and buying one which was 120 bucks and it ended up just being a
corroded wire to my battery. But your looking at one from a junk yard so it shouldn't be too bad.
Good luck.
MuscleInc1320
my fan seem to not work randomly, the car hesitates to starts at times, my ac blower motor isnt working, so sense the ccrm is connected to all those i figured i would try one from a junk yard. would a ccrm off a 94/95 v6 car also work or are they different. what about the 4.6 models?
CC'S95GT
Hampton ,Ga.
The CCRM has the a/c compressor, fuel pump, hi and low speed fan relays.
The blower motor isn't part of the ccrm.
The engine hesitating to start at times probably isn't caused from the CCRM either.
Rad fan. maybe ccrm related. The fan motor connector has been known to melt, motor itself goes bad and wiring issues can also cause the fan not to work.
Addermk2
again, you are probably not having CCRM issues... read the above post and start troubleshooting
