I thought I got some stuff fixed.... Need help
CanaryGT
Phoenix
Well since my old oil pressure gauge went kaboom (just the line broke but it still pissed me off) I installed a new one and I also found that my car was making a funny noise..... Well I found out that it was this little guy....
http://www.mustangmagicparts.com/motorcraft-ev998.html
So yea. When I turn it off it sounds like a little blow off valve.
95gtdrop
sacramento
Re: Got some stuff fixed
when you go to install that pcv valve, put in a an oil seperator while your at it.
the seperator goes between the hose that goes from the pcv to the manifold. keeps the oil out of the intake
CanaryGT
CanaryGT
Phoenix
Found out that it still makes the noise with the new valve.... hrm....
CanaryGT
CanaryGT
Phoenix
But wouldn't that be a consistent sound as opposed to only when I turn off the car? Also, the sound is from that valve I replaced I just dont know why it makes a loud poof sound when the vehicle turns off.
maybe you can't hear it over the motor noise.
IDK man , I'm not there. I'm just trying to give you something to look for. Funny noises are hard to diagnose via the internet
CanaryGT
CanaryGT
Phoenix
True that. I guess I can explain it more. It comes from the PCV valve when I turn off the engine. I know because I replaced it and it still makes the noise. If I start the car up and listen close to the valve nothing happens. Idle or when throttle is applied.
CanaryGT
CanaryGT
Phoenix
Exactly. Ill get my camera and video it for ya tomorrow if I can. Its really really weird. And I dont know why it does it.
CanaryGT
CanaryGT
Phoenix
Well upon further investigation that sound does continue when the car is running. So Ill check my spark plugs...
