IAC-Stubborn
NORTON98
I have a problem and I have already figured out that its the IAC valve. I started to take it off(2 little screws and off it goes on the end of the plenum) but the bottom screw wouldnt budge. I accidently dog eared it a little bit. So I stopped trying to unscrew it in fear that I would mess it up more. My question is do I need an impact tool to get it off?
scarface
Guest
NO! impact would strip the thread out..penetrating lube. If the threads go drill the head off, remove the IAC, then use vise grips on the shaft of the screw.
MAKE SURE YOU ARE USING THE CORRECT SIZE TOOL TO FIT THE SCREW!
DropTopPony
Retired Staff
South Jersey
I hate when that happens...I keep a set of old drill/screw bits in my toolbox that i use when this happens. I will stick the old bit in and hammer it into the stripped head and make a new indentation for it to bite on...sometimes it works, when it doesn't you gotta cut it off.
N
NORTON98
Alright, thanks guys! Im going to put some liquid wrench on their tomorrow! I better upgrade that damn screw to something stronger also.
Mike
98armygt
you could also use a bit that has the little ribs on it to help grip the screw better. i use those just to reduce the chance of stipping out screw heads.
Gnrfreak95
